head stud TQ specs?
Old 06-26-2006, 01:06 PM
Senior Member
Country Boy's Avatar
Default head stud TQ specs?
What torque specs are yall using for FI? I have 12 pt. ARP head studs and 6.0 MLS gaskets.
Old 06-26-2006, 08:21 PM
chriswtx's Avatar
me too...
Old 06-26-2006, 08:40 PM
smokinHawk's Avatar
are you using the lube or motor oil.
best to use the stock torque spec, though i tightened up mine a bit more, think it was about 80ft-lbs
Old 06-26-2006, 08:43 PM
TT-TECH Veteran
Inspector12's Avatar
Well ARP says 65 on all the 15mm and 27 on all the 10mm, but I usually go 80 on the 15 and 30 on the 10 mm though just what I do I have never had a real problem with it due to either the TQ spec or gaskets. Some others will chime in on there procedure though. I go up in 10 lb increments after 50 or so. I let them sit over night and re check them etc...
Old 06-26-2006, 09:08 PM
Senior Member
I went ahead and went to 75 with moly lube. I didnt know the 10mm was that much. Mine are at ~13lbs.
Old 06-26-2006, 09:10 PM
Restricted User
crazykid's Avatar
On all the cars I do 35-55-75 and 25 on the 10mm
Old 06-26-2006, 09:11 PM
Senior Member
hummm... guess I better tighten the 10mms... lol I had them at 13lbs when I was H/C with no problems. Better safe than sorry
Old 06-26-2006, 09:18 PM
bowtieman81's Avatar
I would not go much beyond what ARP recommends for tightening specs. They are a high quality fastener and I think ARP would give torque specs that are approaching yield. If you have a good torque wrench I might bump it up 5-10 ft lbs. Otherwise let her be.
I do think for FI it would be wise to re-torque the head bolts are a heat cycle as ARP recommends. This should help counter the setting that will take place.
Old 06-27-2006, 06:43 AM
Senior Member
On the TQ paper they said that the TQ spec is usually 75% of the fasteners yeild.
Old 06-27-2006, 07:22 AM
LS1Tech Sponsor
Slowhawk's Avatar
We ussually torque them to 80ft/lbs and 25lbs for the smaller ones with the ARP moly lube..
Old 06-27-2006, 07:30 AM
MiaSSmaro98's Avatar
guys were can u get like a book or a sheat the states all the tq ratings for every part in the engine?
Old 06-27-2006, 07:46 AM
This is a fairly standard target for a good fastener. It helps to prevent overtorquing due to the many variables in bolted joints. Like I said, if you have a good or calibrated torque wrench, you could probably bump up the torque 10 ft-lbs. Yield point on the 15mm bolts would be about 86 ft-lbs.
Old 06-27-2006, 08:08 AM
Senior Member
I may just leave mine at 75ft/lbs. I dont know if I have to take the rockers back off to get to the bolts again.
Old 06-27-2006, 12:05 PM
67Firebird455's Avatar
Yeah, I know if you have a deep socket, it'll hit the rocker brace, I snapped one of mine pulling the heads off, not paying attention while it was still in the car.
Quick Reply: head stud TQ specs?
