Would this cam work for the Incon Kit
Possibly might change from Procharger to Incon Twin Turbo Kit would this cam work ok?
214/218 .540/.550 114lsa
Should I swap it out?
If so what specs?
Thanks,
Jason
If so what specs?
Thanks,
Jason
You should be just fine.
I'm leaving in my 236/236 .580 .580 112LSA cam on a new stage 3 kit.
The Buick GN guys have a 108LSA from the factory and the aftermarket cams grind them on a 110 & 112LSA.
Your cam... The duration is small, the lift is light, and the spread (LSA) is the typical wide that everybody says is best. That cam is just fine. "I" would go bigger, but of course you can make up the power with a simple wastegate adjustment. ~Joshua
