Installing a BOV Greddy type s
Old 07-27-2006, 12:01 PM
JerikSS's Avatar
Default Installing a BOV Greddy type s
I just installed a greddy type s bov and its not working??I am running vacum of the brake booster.. I plugged the vacum from the top, and left the bottom open...
Can anyone help??? I have no idea why this thing is not working? is there somewhere I can go with diagrams and pics and stuff, I just hate that this thing is not working...
Old 07-27-2006, 12:05 PM
Boostaholic's Avatar
I haven't ever hooked up a BOV with 2 lines going to it, my TIAL 50 only has the top and it works just fine hooked up to anyplace behind the throttle blade.
Old 07-27-2006, 12:09 PM
JerikSS's Avatar
....so i should find another vacum source different than the brake booster????? that is behind the throttle body???? where?
Old 07-27-2006, 12:21 PM
MECHAM's Avatar
mine is on the bb..works fine. .
Old 07-27-2006, 02:32 PM
SUPER DAVES Z's Avatar
I installed mine like the dsm guys. Just hook the bottom port to the turbo (I ran mine right off the compressor). I initially tried it the way you did but this was the only way i could get mine to work.
Little DSM write up
http://herpetology.com/dsm/bov.html
Old 07-28-2006, 06:29 AM
MiaSSmaro98's Avatar
yeah some bov have 2 ports but good thing my tial only has one
Old 07-28-2006, 08:39 AM
KenC5's Avatar
Ok I have had that BOV and this is what you do.
1. Top port goes to your intake manifold/Fpr vacum singal.
2. The lower port goes to your boost singal off the compressor housing. the same one your wastegate goes to. After that adjust the Hard/soft acrew until desired sound. make sure you dont lossen it to much tho, you dont want it opening under vacum. Mine had a nice high pitched pshhhhh sound to it. I loved it. But the type S is not good for anything over 15psi. (they leak then) Any other questions you might have.
Ohh and DO NOT USE THE BAKE BOOSTER FOR YOUR VAC. SINGAL THey have check valves in them. Just use the vac. line from your FPR.
