Sts Please Help Asap!!!
Old 07-30-2006, 07:45 PM
ironexecutioner's Avatar
Default Sts Please Help Asap!!!
I just picked up my STS turbocharged car. I am in the process of taking it home. I am having problems.. I can hear the turbo spool (or at least it sure as hell sounds like it) but my boost guage doesn't show the boost where it should be, my air/fuel ratio guage is sort of showing a rich reading and I do not hear the blow off valve go off at all.. Please help me...
Old 07-30-2006, 07:55 PM
Boostaholic's Avatar
Check your charge pipes, make sure none of them got blown apart.
My charge pipes blow apart if I don't get all the clamps on tight even at 9psi
Old 07-30-2006, 07:57 PM
bboyferal's Avatar
Where'd you pick it up from? Take it back if you just paid for an install... Or are you home yet... Do you have a FMIC?
Old 07-30-2006, 08:06 PM
No I bought the whole car 3 days ago, had sts already on it. (Private sale). Can you tell me what a charge pipe is and where it is located? I cant exactly go over the car with a fine tooth comb until I get home so I am unsure of some of the stuff you are talking about. What is an FMIC? Thanks for your help guys
Old 07-30-2006, 08:11 PM
trtturbo's Avatar
Just give me a call, you have my number. I will try and walk you through some things to check. You can call now; you dont have to wait until tomorrow.
Old 07-30-2006, 08:42 PM
I tried to look at all the spots of silicone. Everything looks ok to me, but the car also wasn't jacked up giving me full access. I don't know if it is just my imagination or not but I also sort of think it isn't quite as loud as it was before upon startup. If the silicone seperated at all would it be obvious or could it be a minor seperation (ie an exhaust leak)?
