New TV81 Turbo Specs & Pics...
Just got my turbo back from the shop 7lbs lighter.
Here are the new specs:
Compressor wheel 108mm/81mm (4.270"/3.177") .95ar housing 5" inlet 3.5" outlet
Turbine wheel 95mm/76mm (3.75"/3.0") .96ar housing T6 inlet 5" outlet
The build is stock LQ4 bore & stroke 6.0L w/new forged pistons & rods @ 9.0:1 compression, Comp XER281HR 232/234 112LSA .595"/.598" lift. Ported 317 heads stock chambers + ARP studs and a LS6 intake with 84# injectors.
Turbo mounted in the front with Z06 LS2 manifolds and 2.5" crossover pipes. Stock PCM & HP Tuners. In a 72 Corvette 3000# 4L80E 4-link 12 bolt w/3.08 gears.
What HP do you think I can make w/15lbs boost at the wheels?
Originally Posted by CHRISPY
370 cubes? I would think through the heavy 4L80E and 12 bolt you'll make ~700ish at 15#s boost unlocked
With a 364 What do you think the spool time and max boost would be with this turbo? Thanks
Originally Posted by engineermike
It will be laggy and max boost will be way higher than you'll want to run.
