O Noes- Oil On The Driveway
since i have boosted my truck it seems to be bleeding some oil- there is oil under the truck only after i go and boost it- when i dont boost and just drive normal there is ver y very little residue under the
i beleive its because im boosting the crankcase- so i went and got a check valve from grainger to put into the PCV system to stop boosting the crank case- I just want to make sure this is it- I beleive it is comming out of the breather- on the valve cover all down the side of the block and causing it to burn off in traffic and look like my truck is smoking-
do you guys think that boosting the crank case is the main problem?
