air pump/ tilton pump
Help Please !!!!!!!!!air pump/ tilton pump
Is the power source for the stock air pump for pollution control enough to run the tilton oil pump or is the source only on while warming up....???
Where can I plug this to please......
I believe that the air pump is only on for the first minute or so when you start your car. I too will be running a scavenge pump and haven't even thought of where to get a power source from yet. Since you are over by the fuse box couldn't you get a source from there? Did you loose your driving lights when you put in your FMIC? If so you could use that as a source and just make sure and keep the switch on at all times.
