Single Turbo Installtion Pics
Old 10-22-2006, 03:46 PM
dpd069's Avatar
Default Single Turbo Installtion Pics
Just finished a single GT40 installation on our sandbuggy.
Thanks for all the tech knowlege from this forum - we couldn't have done it without this boards help.
Made 520 HP at the wheels at about 8.5psi of boost.
Dan Dooley
Phil Dooley
Old 10-22-2006, 04:03 PM
Dragframe's Avatar
holy BIG pics batman
Old 10-22-2006, 04:14 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
That thing is awesome, looks like a lot of fun. What are the specs on the rest of the thing? Engine, looks to me like you used a vette irs in the back, maybe I'm wrong?
Old 10-22-2006, 04:31 PM
bumpin_records's Avatar
deem some big *** pictures but very nice
Old 10-22-2006, 05:18 PM
SSilverSSurfer's Avatar
damn those pics are huge, nice work from what i can see
Old 10-22-2006, 05:26 PM
fastlt1's Avatar
How did you mount the motor and transaxle together? Is that a corvette transaxle?
Old 10-22-2006, 07:49 PM
Dbluegoat's Avatar
i cant see the pictures can you make them bigger?
Old 10-23-2006, 02:37 AM
dpd069's Avatar
By popular demand I have made the images smaller.
Dan
Old 10-23-2006, 04:29 AM
BOONE's Avatar
Default buggy
That is beautiful work, I love it. See now you have me lusting. More pics...
Old 10-23-2006, 04:57 AM
now that is some very nice work
Old 10-23-2006, 07:31 AM
dpd069's Avatar
The tranmission is a Mendeola MD4S2D driven though a double disk Kennedy clutch.4 speed with a 5.14 ring and pinion. Mild steel headers ceramic coated black and with v-band quick disconnect flanges. The motor is a bone stock 98 LS1 (except for new rings and hi-flow oil pump). 4" GN style intercooler with a fan switched to come on with boost. GT40 turbo and a Tial 38mm gate set to 8.7 # of boost. No BOV. Tuned with LS1 edit. Std PCM and modified factory harness. CR aluminum radiator with Spal fans.
The car is a Dunntech chassis, four seat sand car with about 22" of suspension travel front and rear.
Old 10-23-2006, 08:00 AM
MrDude_1's Avatar
sooo... did you keep the paddle tires on it when you ran it on the dyno?? lol
Old 10-23-2006, 10:13 AM
TrakDay's Avatar
Thats sweet. Just curious why you chose such a large turbo though!?
Old 10-23-2006, 11:42 AM
Eric Bazan's Avatar
Who did the coating on the turbo and hot parts. Looks real nice!
Good job.
Eric
Old 10-23-2006, 11:52 AM
e015475's Avatar
GT42 a large turbo? from the sizing we did, I thought we sized it a little small for the LS1 so it would be really good for boost at midrange RPM.
The hot parts were coated by Affordable Powder Coating here in Phoenix. They said black would be rated to a higher temperature, and we thought with all the silver on the car the headers would be lost if they were silver.
Phil and Dan
Old 10-23-2006, 11:54 AM
e015475's Avatar
Can't run the paddles on the dyno - had to use street tires. It is tough to find a dyno that will take it because the rear track width is 83"
TrakDay's Avatar
Phil and Dan
I guess I worded it a little different than what I was actually asking. Are you guys looking to make more power out of the setup?
Ah what do I know. I can't even figure out what size twins I am going to run.
Either way its definately a cool project!
Old 10-23-2006, 12:39 PM
LS1TECH Sponsor
DrTurbo's Avatar
If that is a GT42, then where are the V-bands??? A GT42 uses V-band mounting for the compressor cover and turbine housing. That unit is using all bolt-on parts.
Old 10-23-2006, 12:42 PM
frcefed98's Avatar
Yeah, wierd GT42...my ol GT42 had a 4 inch outlet on the exhaust side and 5 inch inlet on the compressor side. V band connects on the DP to exhaust turbine, and 3.5 inch V band connect on the compressor outlet.
Old 10-23-2006, 12:51 PM
dpd069's Avatar
No, we are not really trying to make more power out of it. With a stock block and the kind of abuse we put it through in the sand dunes, we figured we would rather be safe than sorry. We figured a max of 10PSI. Its not easy to be towed out of large hills made of fine sand at 2,200lbs.
we chose the GT40 instead of a twin setup because of space restrictions and because it is just a little different (most people do a twin setup). Also we initially had plans of during the off season of the sand car using the turbo for a remote setup on a 5.3L truck, so we got the 40 to work with both. Now, after all the fab and install work we realize it is just not a practical plan so I guess we will have to buy another turbo.
The turbo is a little small for the LS1 but as long as we keep the PSI down, we are able to still be in the efficiency islands throught the entire RPM range. Besides, you can only have so much horsepower/torque before you start digging yourself a grave in the sand. The trans is only capable of handling up to 550hp so we also had to be careful about that (the next upgrade trans is the Albins at 18,000 dollars, a price we really cant afford to pay) so we had to limit our boost to accomodate the trans.
About sizing... it took me 2 or three weeks to size it. Finding out what other people are using isn't easy. They might tell me the general size but as for turbine housing sizing and A/R ratio, etc., you are kind of on your own. A lot of the turbo kit companies won't tell you specifically what they use, i assume to protect their business. We ended up knowing what we wanted but due to the advice of one of the staff at Limit Engineering (in Lake Havasu Arizona, where we bought the turbo) we ended up changing it a little at the last minute.
Fabing the setup is probably the hardest but I think a close second is choosing which turbo(s) to use for your application. It just takes a lot of time, research, and patience.
Dan
Quick Reply: Single Turbo Installtion Pics
