Procharger and TB connections
Old 10-25-2006, 06:28 PM
9silverbird8's Avatar
Default Procharger and TB connections
The tube on the TB that I'm holding with my middle and index fingers. Right now it's not hooked up to anything since I switched to a LS6 PCV system. The hose from the Procharger inlet hat is now connected to the passenger side valve cover where the LS1 PCV originated. So my question is this. Should I hook a line off that TB tube and tee into the line to the valve cover when the original PCV was? Right now that tube off the TB is blowing metered air out to nowhere correct?
Old 10-25-2006, 06:54 PM
andereck's Avatar
Cap it off.
Old 10-25-2006, 07:31 PM
Been there done that and it blows right off the first time I get into the throttle
Old 10-25-2006, 09:04 PM
Senior Member
Country Boy's Avatar
use a 3/8 cap. Mine hasnt blown off yet.
Quick Reply: Procharger and TB connections
