adj fuel pressure regulator question ....
Old 10-29-2006, 01:25 AM
ssdriver27's Avatar
Default adj fuel pressure regulator question ....
I bought this boost referenced adjustable fuel pressure regulator, I should have asked ahead of time but will this work for me? the reason I ask is, I read a little closer and in the description it says adjustable from 36 - 45 PSI If it will not work what should I go with? if it will work any advice or help with installing and adjusting would be appreciated as there were no directions included. I also bought a 255 lph walbro fuel pump to go with it if that makes a difference. thanks ~Guy
http://cgi.ebay.com/ebaymotors/MSD-T...QQcmdZViewItem
Old 10-29-2006, 10:00 AM
ABeasst's Avatar
you need a regulator capable of running up to about 60 depending on if you reference it.
Old 10-29-2006, 10:13 AM
single digit dreamer
parish8's Avatar
here is the one i have. i run my base presure at 58psi and under boost it will take the fuel presure up to over 70psi. the one you have pictured looks like it is setup only for hose clamps. not sure if i care for that.
http://store.summitracing.com/partde...5&autoview=sku
Old 10-29-2006, 12:25 PM
ssdriver27's Avatar
thanks
