carb style manifold, how to attach map sensor
Old 11-13-2006, 11:06 PM
SVC707's Avatar
Default carb style manifold, how to attach map sensor
i just got a GMPP carb manifold, but no bung or hole for the map sensor.
the elbow i have has two 3/8 or larger, not sure, fittings coming out one ill use for the brake booster. the other i can use for boost gauge, fuel pres. regulator, bpv,
how did you guys attach your map sensor.
Old 11-14-2006, 04:34 AM
Brent@LPE's Avatar
you can use a peice of vacum line and remote mount the map sesor on the firewall
Old 11-14-2006, 05:02 PM
99SS-T's Avatar
Ya the sensor grommit comes off and easily accepts some vaccum line. GL man
John
Old 11-14-2006, 05:05 PM
SVC707's Avatar
i went and ordered the fitting by az power to help simplify all the hoses. the fast manifold had ports everywhere i could use but now i only have 2 and i have to share it with alot of things.
