cam specs for a 403LS2 w/ s80...
Old 12-03-2006, 09:34 AM
MyWs62FaST4u's Avatar
Default Which cam for a 403 LS2 w/ S80?
what specs would you recommend?
i want to use the car for some autoX, like a previous poster said- "i wont need to go higher than 4th gear in most cases.."
I do however enjoy the highway, and it wil be very heavy driver on the local streets.. most likely it'll be a comp cam Hyd.Roller...any one using this combo?
Old 01-08-2007, 10:51 PM
anyone?
Old 01-09-2007, 10:21 AM
SonofaBish's Avatar
dude, is there a reason you haven't responded to my PM's??
Old 01-09-2007, 10:43 AM
96 Comp T/A's Avatar
Well, my reccomendation would be something in the high 220's to low 230's for .050 with minimal overlap, maybe on a 115 -117 LSA.
FWIW, my Cam Motion Hyd. Roller turbo grind is closer to 240 degrees with a reverse split. It was spec'd at 364 ci, but it was meant for a pretty serious street/strip motor with no regards to how it idles, gas mileage, etc, etc.
Your best bet in any case, would be contact an expert, either a tuner shop that does a bunch of Turbo builds like LS1speed, or a cam grinder such as Comp or Cam Motion.
Quick Reply: cam specs for a 403LS2 w/ s80...
