Will this turbo work?
Old 12-05-2006, 08:09 AM
347fairless's Avatar
Default Will this turbo work?
Looking to build a STS style rear mount setup on a stock motor.
HKS Style GT45 - Ebay
Inlet (Exducer/Hot Side) T-4 Flange 70.1mm x 82.55mm (2.76" x3.25").
A/R 1.05 Exducer
A/R 0.66 Compressor
Cooling/Lubrication Oil
Outlet (exducer/hot side) 4.25" V-Band
Inlet (compressor/cold side) Ø 109mm (4.25")
Outlet (compressor/cold side) Ø 86mm (3.38")
Compressor major diameter Ø 98 mm
Basically what is the *REAL* size of this turbo in Precision or Innovative terms?
Anything to look out for in regards to the pictures as well?
Thanks guys.
Old 12-05-2006, 08:33 AM
LS1TECH Sponsor
DrTurbo's Avatar
Way to big of an A/R for a rear mount. You'll be lucky to spool that turbo before 4000.
