Turbo pistons, rods
Old 12-30-2006, 10:48 PM
TurboGoat's Avatar
Default Turbo pistons, rods
What are your opinions on the best pistons and rods for a forged 346 running a 76gts
using 317 heads, would like the compression to be 8.5to 9
Old 12-30-2006, 10:57 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,103 Likes on 723 Posts
I'm running custom Diamond pistons and some 6.125 rods + 70cc heads and have 8:1 compression. I had about the same compression when I had 317 6.0 heads. When picking pistons you just have to make sure the manufacturer says that their pistons can support your power goal. I have also heard good things about Mahle and JE pistons.
Old 12-30-2006, 11:04 PM
SuperZ's Avatar
I am running a Mahle -16cc dish with stock heads for 8.7 comp
Old 12-31-2006, 04:32 AM
bumpin_records's Avatar
Im running JE custom turbo pistons
Old 12-31-2006, 09:01 AM
mightyquickz28's Avatar
I'm looking at/for pistons for my T76 enhanced LT1. The LT1 stock head CC is 54cc and I have a 6.0" H-beam rods. How in the world are you guys getting that highly desirable SCR with those long rods in the LS1's with only a 16cc dish on the pistons? Is the LS1 Piston pin just down on the slug so far that you end up with that figure? Also, what prices are you seeing typically for the JE/Mahle/Diamond sets? And what Rings? Hellfire? I found one piston vendor that stated with my setup (383, highly ported stock LT1 Castings with 54cc chambers, 6.0" rods, .049 head gasket compressed height) that he could only get me to 9.3 SCR unless I dropped down to a 5.7 rod.
THanks guys. As always, great responses from the best.
David K. Wilson
'94 Z28 383 A4 3.42
'96 Z28 383 M6 4.10 - T76 being installed
Old 12-31-2006, 09:30 AM
stevieturbo's Avatar
I used a Mahle/Callies combo in my 346. No complaints whatsoever. Very nice bits of metal lol
Old 12-31-2006, 01:40 PM
Outlaw 10.5 Director
FSTR-THANU's Avatar
Flawless performance up to 1500++hp!!!
Tom
Old 01-01-2007, 01:59 AM
HAMRHEAD's Avatar
I am using custom diamond pistons and callies rods
Old 01-01-2007, 03:36 AM
Turbo LS1 SS's Avatar
custom diamonds and scat
Old 01-01-2007, 04:19 AM
BIG BAD BLACKSS's Avatar
Diamonds and eagle H beams with the L19's here.
What do you guys specify as making your diamonds "custom" Did you order em for different ring sizes, thicker ringland, custom shape dish?
Old 01-01-2007, 05:21 AM
Q8CamaRo's Avatar
Diamonds -8.6cc and eagle 6.125 H beams rods
nice combo
Old 01-01-2007, 12:55 PM
custome rod length, custom dish (-22), custon top ring down, custom bore
Old 01-01-2007, 01:28 PM
SSilverSSurfer's Avatar
looks like diamonds are the way to go
Old 01-01-2007, 04:10 PM
MiaSSmaro98's Avatar
diamond is what i will use
Old 01-02-2007, 08:36 AM
Z06PSI's Avatar
Custom Diamond and Callies rods.
Old 01-02-2007, 09:50 PM
M3 Muscle's Avatar
Any clue what HP and RPM rating Callies rods have?
Old 01-02-2007, 10:34 PM
nvmy2000ss's Avatar
Diamond and Lunati pro billets here.
Old 01-03-2007, 05:10 PM
TurboGoat's Avatar
is there an off the shelf Diamond for a 346 with 317 heads that I can use? looking for 8.5 to 9:1
Old 01-03-2007, 06:32 PM
I emailed Diamond themselves today, asking for a part number for my application and goals and they emailed it right back within 45 minutes. Here's his email addy..."Eric Simone [esimone@diamondracing.net]"
I sent him all this so he'd know what to recommend...
How’s it going?
I have a ’96 Chevy Z28 with an 383 LT1. I’m converting to a T76 Turbo and all the guys at LS1Tech.com are recommending your forged turbo/blower pistons. Here’s the info on my application.
Motor Type: stock cast iron LT1 block
Bore: 4.030
Stroke: 3.75
Rod Length: 5.7” (H-Beam, Forged and bushed for full floating piston, capable of supporting 1,000 Hp)
Heads: Stock Aluminum LT1 castings, heavily ported by a pro w/54 to 58cc combustion chambers
Head gaskets: Nominal compressed height of .049
Anticipated Horsepower: 600 Rear Wheel
Fuel: Premium Pump gas for the street, race gas at the track
Anticipated Usage: 80% street, 20% strip
Desired Static compression Ratio: 8.5:1
Do you have a Diamond Piston part number I can refer to when I talk to a Diamond Distributor?
Thanks!
David K. Wilson
’94 Z28 383 A4 3.42
’96 Z28 383 M6 4.10
He replied :
My part number #11426 gives the compression you want, but is for a 6" rod - not a 5.7 rod.
31cc dish - and it's designed for blowers/nitrous use.
$750.83 per set including pins - rings are extra.
Thanks for the e-mail..!!
Eric
Old 01-04-2007, 04:24 AM
30thTA0525's Avatar
check with victory racing engines... they can get you that exact same set up for $600 and some change.. im buying the exact same set..
Quick Reply: Turbo pistons, rods
