lsa/icl what are the benifits of going bigger or smaller
Old 01-15-2007, 03:57 PM
lmt0705's Avatar
Default lsa/icl what are the benifits of going bigger or smaller
im still cam hunting and I was wondering what are the benifits of going with a large (almost stock) intake center line like in the gt2-3 which is 118.5 versus a tighter 114 or even a 112 icl, are the intake center line and the lobe seperation angle always the same if the cam is to be degreed in at 0? or does the lsa have a different effect on power band? Ive read the cam sticky and it doesent talk much about the icl and lsa other than what it is.
Old 01-15-2007, 05:12 PM
lmt0705's Avatar
i should have mentioned that im running a d1sc with 14-16 psi and 9.3 compression, with patriot lq9 heads
Old 01-15-2007, 05:54 PM
Steve01SS's Avatar
Typically... a lower LSA cam will lope a lil more at idle (choppier) and the RPM powerband will be slightly lower than a higher LSA cam. Also with FI, you can lose some boost with a lower LSA cam. You kinda have to work harder to build boost.
On a side note, I'm running a G5X3 on a 112 LSA and see 8 psi with a P1SC on my H/C 346 with a 3.6" pulley. I feel that with a different cam, the same sized pulley will make more boost. Car was originally N/A, thats the reason for the cam. It still makes good power, but I'm contemplating changing it out.
Old 01-15-2007, 07:34 PM
lmt0705's Avatar
so do you think the gt2-3 would make power too high in the rpm range?
Old 01-15-2007, 09:01 PM
Steve01SS's Avatar
Nah.. the difference in the band shift between a 112 and a 114 is like 500 rpms..
The Gt2-3 is supposedly a good FI cam that doesn't lope and sounds stock... There's a few out there, I'd go a lil bigger though.
Old 01-16-2007, 02:50 PM
lmt0705's Avatar
whats a little bigger that the gt 2-3 without getting huge?
Old 01-16-2007, 05:55 PM
stevieturbo's Avatar
how long is a piece of string ?? there are dozens of options....
Something like a 220/224 on 114 or 115 would probably be common.
Quick Reply: lsa/icl what are the benifits of going bigger or smaller
