Question on TTI kit
Question on TTI kit
Hi im new to this forum and u guys definitely have great information on here.
I have the tti kit with the 76mm with the front mount intercooler. I need to tune the car and am wondering what boost controller you recommend, low cost heads and what tuning program works the best or I was also thinking of getting it tuned at MTI in houston any ideas?
My goal is to have 475 to 500 on stock internals safely.
pick up a set of 6.0 truck heads(you can bolt them up as is), im in the process of trying to find some, which for some strange reason is not working, lol
and you can use a manual boost controller(turbo smart,turbo logic, hallman, etc.) or if youve got the cash pick up the AEM Tru-Boost, or eBOOST2 both are bad *** pieces,
MTI, GFORCE, CONLEY, all those places would be fine for the tune.
im running that same set up btw, good luck
The most economical boost controller is the manual style, the draw back is it always starting to push the wastegate open. An electric vbc is the way to go because it doesn’t send a signal to the wastegate until the ask for boost is met. The best tuning software is HP tuners. If you have the software send us a file and we will get you in the zip code.
George Scott
Turbo Technology Inc
George Scott
