Will spraying Alky (on a Maggie) change the AFR???
Old 02-10-2007, 04:07 PM
SideStep's Avatar
Question Will spraying Alky (on a Maggie) change the AFR???
Will spraying Alky (on a Maggie) change the AFR... I am seeing (obviously) richer numbers when hitting the Alky. Just double checking...???
If so, what AFR should I shoot for??? Was using 12 to 1 before Alky kit was used.
Old 02-10-2007, 06:41 PM
DeltaT's Avatar
Of course. You are changing the Air Fuel Ratio (AFR).
Anywhere from 11.0:1 to 11.4:1 is a pretty safe AFR unless you are getting knock.
That's with the alky on. That's a little richer than just straight gas.
What kind of boost are you running?
Do you still have the 30# injectors?
Jim
Old 02-10-2007, 07:59 PM
SideStep's Avatar
Jim
8 pounds of boost with SVT 42# injectors..., not my car, a buddies 2003 ZO6 with a Intercooled Magncharger...
Thanks for the info...
Quick Reply: Will spraying Alky (on a Maggie) change the AFR???
