Exhaust leak at Flange for turbo...what to do??
The title could be a smidge misleading. I have a flange on the I-pipe that connects to a pipe that runs to the exhuast housing of the STS turbo kit. Without welding this as crap would get all in the pipes and kill the turbo, what kind of setup can I use to get it to seal. Water/condensation is dripping out when the car is out idle at the flange. I've used an aluminum gasket and tightened the crap out of the bolts...but it still leaks.
Also, please no machine shopping...I don't have time for that right now...too much has already been done to start going backwards. Maybe some silicone RTV stuff and a double gasket...copper gasket? Please help...thanks!
As you can see from the picture, it is the flange over on the right...not anything that actually connects to the exhaust housing or turbo itself...all that is good
I bought a copper gasket that has a rounded bead that goes inside the pipe where it fits to the flange. I also bought that high-temp copper stuff to paste a little on the sides for extra seal. I hope this works...I've come too far to get on the dyno Tuesday and make like 4 psi b/c of an exhaust leak
I un-did the flange last night and used a jack to hold the turbo up. I tightened the flange so much, I about sprained my wrist getting the bolts off...it was SOOOO close to being stripped out (that would have really sucked!!)
