Pics of my new custom front mount what ya think
Okay i was having a few probs with IATs with the 408 and 3.4 pulley and I was at my buddies shop and he happened to have a brand new just in Garrett intercooler core good for upwards of 800rwhp. The idea flashed and thats all it took. We spent alot of time on valentines both getting in trouble for working on it till 8pm but after all was said and done it was in, all looking great!! I got to grind down the welds a bit and then either polish it or chrome it. The kit has the garrett core, 3in mandrel bent aluminum piping, a very nice Tial race waste gate, and 8 ply silicone connectors. This kit involved no cutting of the front, is simple to remove and install and works very well my IATs went down over 50 degrees over the last time I scanned the car in full boost. Sorry for the crappy pics camera phone is all I got
Originally Posted by Country Boy
Looks good! That intake tube and BOV placement looks very familiar
Originally Posted by 6techniques
is the IC angled down to a certain degree, or it it parallel to the ground?
cool, I couldnt really tell from the angle you took the pic. What kind of hp is that ic rated at?
Thats a good place to put the IC, the front of these cars where most put them (including me) is a pretty dead zone air flow wise. With the air dam and the IC at that angle you will have a lot more air moving through there then at the front. My only concern was losing some airflow through the radiator but that looks pretty good, less bends in the pipe the better..
One thing please see if you can figure this out I have alot less bends in it now, larger pipe 3 in versus 2.5 in and a much larger core and better flowing but I am only seeing 9.5 psi versus 10.5 to 11 psi that i had with the old set up. Any ideas I checked my connections and they look good
Boost is a measure of restriction. Higher flowing heads = less boost ,but more power at less boost. Same principal with IC pipes. Biger pipe flows better.
or
What he is saying below is very true also.
or
My core is similar in size to yours (6"H x 23"W x 4.5"Deep) , but with the hot air channels oriented vertically I have much lower restriction with 36 hot air channels:
If we assume you have a 3" deep FMIC, then your internal flow area (the total size of all the "windows" the hot air sees when it enters the intercooler), we get:
3" Deep
times
9 channels
times
5/16" (the common internal width of that type IC)
equals only
8.34 square inches of internal flow area
versus mine (measured like yours with 3" depth instead of the real 4.5"):
3" Deep
times
36 channels
times
5/16"
equals
33.75 square inches
Four times the flow area in a similar rectangular shape.
Mine has a rated pressure drop of 1psi at 1089cfm. In real life I see less than .4psi difference between input pressure and output pressure, but I'm only putting a max of about 800cfm through there right now (501 rwhp with 7.2# of boost, 383 Vortech S-trim).
What are your actual core dimensions?
I estimated:
Length Across - I figured 22"
Depth - went with 3"
Height - looks about 8"
Garret rates their 703518-6019 core at 600hp:
Length: 24"
Depth: 3"
Height: 7.9"
I think you traded a cleaner install for a more restrictive IC. I also have a problem with anyone telling you the core is rated for 800HP. By its looks and layout I would have said 400-500.
Install looks nice and clean, though.
Jim
Okay i went out and measured and it looks like it is the 24"x8"x3.5" also was talking to a few guys and since i do know that it has alot more tubulators inside it will cause extra drag and I have alot of guys saying the bigger pipe will cause boost to fall a bit. i dont know got to get my fuel pumps in and then go retune and get it all situated. Anything you guys can see that I might do that will make it better please feel free to let me know thanks alot.
