Size WG and BOV
Old 02-15-2007, 07:04 PM
93 4mula's Avatar
Default Size WG and BOV
How do you know what size BOV and Waste gate to run? Different size for amount of hp you want to run? Looking to push 1000rwhp or really close to it
Old 02-15-2007, 07:22 PM
Boostaholic's Avatar
I have twin tial 44m gates and they worked fine for all boost levels I've tried, and a single 50mm bov but I've heard of people running two before when they are running a lot of boost
Old 02-15-2007, 07:32 PM
93 4mula's Avatar
I am running a single turbo setup. So would a 50mm work for what I nieed?
Old 02-15-2007, 11:35 PM
Snyper's Avatar
absolutely.
Old 02-16-2007, 08:03 AM
RealQuick's Avatar
GT47-88 right? I would go no less than a Tial 44mm WG and start with one 50mm BOV.
You an get a JGS 50mm wastegate for ~$379 ... about the same price as a 44mm Tial.
http://www.jgstools.com/turbo/index2.html
Old 02-16-2007, 09:30 AM
7 Second Club
Phil99vette's Avatar
You can get the Tial WG for just over $330.
Phil
Old 02-16-2007, 09:53 AM
LittleV6's Avatar
Waste gate size is going to be dependant on turbo and motor size AND how much boost you want to run. If you want to run a lot of boost you won't need a very large waist gate, but for low boost a larger WG will be required to be able to bypass enough exhaust gas to regulate boost.
Old 02-16-2007, 11:17 AM
TINKRD's Avatar
i'm going to be running a 408ci w/ a GT47-88 turbo. i have a turbonetics godzilla BOV that was given to me as a bday present
what WG should i go with?
Old 02-16-2007, 11:19 AM
LS1TECH Sponsor
DrTurbo's Avatar
They are nice as well. We carry them on the shelf. The 50's are the best bang for the buck.
Old 02-16-2007, 05:30 PM
NA$TY-TA's Avatar
I love my Turbosmart 48MM WG....... no problem running 7psi with my S88......
She's a Big boy... Heres a Pic..
Kyle
Old 02-16-2007, 05:46 PM
ls1king000's Avatar
kyle, do you run a front sway bar?
Old 02-16-2007, 05:51 PM
NA$TY-TA's Avatar
No i do not..... and i do drive around on Skinnies with power steering..... it has it moments and i do **** people off when im getting on and off the freeway when there is a sharp turn........ im that guy doing 30mph LOL
Kyle
Old 02-16-2007, 06:02 PM
93 4mula's Avatar
So a 44mm WG and 50mm BOV will work for what I need? Its a 385ci LT1 with a gt47-88. Looking to run max of about 20-24psi
Quick Reply: Size WG and BOV
