Give me some info on this turbo cam - specs inside
Old 03-20-2007, 12:36 AM
detroit_903's Avatar
Default Give me some info on this turbo cam - specs inside
Called comp cams up today. I told them I was looking for a turbo cam that will give me a lopey idle for me lt1. They gave me 224/224 536/536 114. Given those specs would that cam be good. I have the lt4 hot cam and wanted to replace it with this cam. Will this custom cam sound better then my hotcam and work better??
Old 03-20-2007, 08:57 AM
RealQuick's Avatar
It should be good. It wont lope too much... and will actually sound more mild then the hotcam. Alot of sts lsx guys are having success with "blower" grinds. The typical blower grind for LTX's are 218/230 or 224/236.
I am doing a frontmount T88 and will be using XFI lobes I spec'd that is 224/224 .573/.565 114LSA.
