IS this turbo capable of 800whp?
powermaster (not the best of brand selection, but i need to fab up everything first ) t70 TO4 ' P ' Trim Turbine wheel - 64.5mm / 78mm
TO4P compressor wheel - 69.11mm / 91mm
.70a/r compressor housing
I dont know much about compressor maps or what numbers translate in to what power wise, lol. Soo i figured you guys could help.
Looking for 800whp, quick spooling, some lag is ok, also it cant fall off on the power band to soon. I need to make power on the big end of the RPM range as well because the car is a 6 speed.
That turbo will fall a couple hundred HP shy of your goal asuuming it's a 65mm turbo. Not to mention it will spool very quickly but will drop off after about 5,000rpm's with that A/R ratio. Exhaust backpresure will overcome any gains at that level. What turbo is it exactly? Please don't tell me it's an Ebay turbo!
LS1TECH Sponsor
Not even close...600 is asking alot.
