My poor stock replacement head gaskets
Old 04-26-2007, 07:21 PM
nick97ta's Avatar
Default My poor stock replacement head gaskets
I put this in the LT! section, but figured it could go here 2.
this is what happens to the gaskets on 12psi. with a gt42 and 10:7.1 compression.
I now have some cometics and ARP bolts to put back on the car.
Old 04-26-2007, 10:25 PM
tirefryin_s10's Avatar
ahaha YEE HAW!!!
Old 04-27-2007, 02:21 PM
otherwhitemeat's Avatar
It was the gaskets fault, it was your tune, gas, and plugs.
Old 04-27-2007, 03:44 PM
6 Second Club Moderator
LASTLS1's Avatar
You might me a percent or two away from a perfect tune.
Old 04-27-2007, 06:46 PM
nick97ta's Avatar
I thought it was just a weak gasket, but you guys seam to think its my tune. If it is my tune what do you think I should do to get it better?
Old 04-27-2007, 10:30 PM
BIG BAD BLACKSS's Avatar
More octane or less advance? Go to a good ahop that knows these cars and have a good dyno tune session with them.
Old 04-28-2007, 07:25 AM
nick97ta's Avatar
If it was octane or timing and not just to much cylinder pressure, I should have damage to the head or piston, correct?
If needed I can get some pics of the pistons or heads, I have not had the time to put it together.
Quick Reply: My poor stock replacement head gaskets
