Need some help for the Magna Charger!
Hey guys, putting the vette back together I noticed oil in all the intake ports and the throttle body, I don't believe that is right so has anyone run into this problem before and what could it be. I think it might be the manifold gaskets but not sure. It is the old non-intercooled version from 2002 era.
Its more then likely from your PVC system not the seals. Same problem everyone else has with oil getting into the intake whether its F/I or N/A. Its a pretty common problem. Get a catch can for your system and you will be fine.
