boost and fuel pressure sgague install
I am trying to locate a place on the rails to hook the fuel sender up to.
I have an LS6 intake and located the schrader valve but it doesn't look like it can be removed from the rails.
Do I need custom rails?
What are the adapters I need?
As for the boost, I have the 1/4" nylon tube and "T" but haven't located a place for it. My vaccuum line are all 3/8". Is there an adapter or a better place to tie this in as well?
Thanks
Thanks
for the fuel pressure guage, the shrader valve can be removed and then you need an adapter for it (check with sponsers, id bet nasty performance might be able to help you out for this part)
