STS KIT-Is it possible to have toooo much vacuum pressure?
Old 05-22-2007, 06:24 PM
socalstreetracer's Avatar
Default STS KIT-Is it possible to have toooo much vacuum pressure?
I dont seem to have any vacuum leaks but my vacuum is reading at -64 at idle. I can enter boost just fine but when im driving and I let off the gas the vacuum goes to -99. Anyone had this problem?
Old 05-22-2007, 07:38 PM
engineermike's Avatar
That's normal, with or without a turbo.
Old 05-22-2007, 07:44 PM
I meant to say the vacuum reading through my boost controller, is this still normal?
Old 05-22-2007, 07:52 PM
If it's hooked to the plenum, then that's normal. If it's hooked up to the charge piping, then it's impossible.
Mike
Old 05-22-2007, 08:01 PM
I'm not sure its a greddy boost controller. My vacum used to be around -40 when I was stock but now I have cam/heads, i had a vacum leak a couple weeks ago and I found the problem. I fixed the hose and now my vacum is crazy.
Old 05-22-2007, 08:05 PM
It's normal for any gas engine to go to full vacuum in the intake plenum under decel. -99 kpa is full vacuum, or close to it.
