Dyno error in your favor, collect 100 hp
Old 05-31-2007, 11:27 PM
Pathological Modifier
Ryan K's Avatar
Default Dyno error in your favor, collect 100 hp
OK, so we were having some isues with TTi's dyno Tuesday...
One run 10 psi SAE corrected to 704 hp. But upon closer investigation, the CF was WAY off at 1.1ish. So that run uncorrected comes out to 612 rwhp:
Here is the SAE graph:
So I am at 600+ at 10 psi Which is still fantastic for that boost level.
We did up the boost to 12 psi for a couple of runs to see how everything was doing... those pulls resulted in 676rwhp SAE. Which is still higher than the best pulls with the old system running 16-17psi.
I was getting some wierd boost spikes of 15psi as we first come on boost that resulted in some just insane power levels at very low rpm:
So anyway, it looks like I am having several issues.
1. Boost controller spiking (no idea whats going on)
2. Accel DFI Wide band is not reading accurate not even close, reading 14:1 when the Dyno read 12:1. (no Idea whats going on here)
3. Fuel Pressure issue, currently looks like the Fuel pressure regulator is the cause... Damn me for buying a freaking China special.
Anyway I just got the files and I believe in being honest with you guys.
Looks like I have some work ahead...
Ryan K.
Old 05-31-2007, 11:32 PM
frcefed98's Avatar
All small issues that you'll have figured out in no time, keep posting up these awesome numbers, TT really out did themselves with this kit.
J
Old 06-01-2007, 02:40 AM
NA$TY-TA's Avatar
Sweet........................ Get Her Done.......
Old 06-01-2007, 05:41 AM
cablebandit's Avatar
i like a man that posts the good AND the bad. You need an eboost2 . locked or unlocked converter?
Old 06-01-2007, 08:09 AM
Ryan K's Avatar
All pulls are unlocked, I killed a transmission a few years back doing the prototyping of the NX MAF system cause I was hitting it locked.
Old 06-01-2007, 09:28 AM
hmmm...i always lock mine cause thats how i run it at the track once i hit 110mph
oughta be 9s easy for you!!
Old 06-01-2007, 09:31 AM
Turbo Addict
RICE ETR's Avatar
Regarding the WB....not to point out the obvious but when MM got his car back from TTi with his race kit....his WB was before the turbo not after as it should.
Either way, glad to see you finally making some numbers...looks promising.
Old 06-01-2007, 10:11 AM
qqwqeqwrqwqtq's Avatar
What boost controller?
Old 06-01-2007, 10:20 AM
Ryan K's Avatar
The Boost controller is the MSBC-1 from Innovative/Exhile.
And the WB is right after the turbo as it should be...
Old 06-01-2007, 10:23 AM
you should dyno locked/unlocked or run at the track that way to make sure that converter is holding all the hosspowah you are putting to it. I know my PI Vig converters never held
Old 06-01-2007, 10:28 AM
RealQuick's Avatar
Still great #'s! What size turbo again?
Old 06-01-2007, 10:30 AM
kp
kp's Avatar
IMO its a lot easier to tune locking the converter, just make sure its locked before you nail it on the dyno and you shouldnt have any problems. But i'm sure those guys know what they are doing.
Thats a big difference in widebands, I have alwasy been pretty close with the in-car widebands but sometimes the DJ sniffer can get weird. You can put the dynojet sensor where the FAST sensor in and see what it reads. One well placed little air leak near the sensor and it will screw up the readings prety well.
Old 06-01-2007, 11:39 AM
Ryan K's Avatar
The turbo is Turbonetics new F-1 82mm Mid-frame t-4.
Ryan
Old 06-01-2007, 11:52 AM
I always had that issue on the dyno with the msbc. (though it worked fine on the street/track). What I've done that helps is put a .030-.040 bleed in the hose going from the increase solenoid to the top of the wastegate. Seems to soften the hit to the gate and smooth out the roller-coaster effect.
Old 06-01-2007, 12:45 PM
Ryan K's Avatar
Cool, thanks for the advise!
