New set up, any ideas what kind of power to expect?
We have recently installed an LS2 stroked to a 402, 10-1 comp, it has all forged internals, afr 225's, comp blower cam, fast intake, bbk tb, 60lbs injectors, aftermarket fuel system, kenny bell boostapump, kooks 1"7/8 long tubes, kooks 3" exhaust, vortech JT trim s/c, 8 rib set up, 8" crank pulley, 3.125 blower pulley, custom i/c, water meth, 4.10 gears, stage 5 dte diff, will be flying a well known tuner to tune the car. Any ideas what we should expect for hp? What should the car run in the 1/4? All this in a 98 convert vette. Is there anyone running the same blower, if so how do you like it? Any replies will be appreciated!!
Dumb Ass Vette Moderator
With the right tune, you should be able to hit the 850ish range pretty easy. But,..... I think you will run out of the fuel before that. Bigger injectors and fuel pump will be needed. With the 60 pounders, I think you should be in the 700ish range pretty easy.
Keith
Keith
Keith
Keith
