what is your ECT and IAT at the end of a pass?
7 Second Club
just curious as i finally remembered to log several things at the track this weekend...
my IAT got up as high as 140 (it was only about 85* outside) i have a 3'' intercooler i think its a 30x14x3 or something....
my ECT got as high as 225 by the end of the run....
all this was on 1/8 mile passes....
Thanks,
Tyler
Thanks,
Tyler
Originally Posted by ty_ty13
i understand that especially with A2W... there was a F2 mustang there at the track with 55* IAT's.... he had rock salt, ice,water and a mixer though....
Originally Posted by 69vette
What does rock salt due for the temps? Seems like the large chunks of salt would get clogged in the intercooler core if they are running that in the water.
chemistry
sub freezing water temps
We typically see 34° or so at the start of a pass, and about 55° at the traps (1/4 mile) with the A2W and the 106. A2A was pushing 130° but that was working the turbos pretty hard on the twin setups.
Coolant never really gets much over 200, but they usually sit until it's time for the burnout.
7 Second Club
Phil
Originally Posted by Phil99vette
Most people add a filter inside the water cell to keep the rock salt chunks out of the intercooler.
Phil
Phil
Keep in mind adding extra salt really kills the intercooler, there is already salt in bagged ice and it causes extra corrosion inside the unit. Flush the I/C after racing with a mixture of distilled water and water wetter to keep it in good shape.
do you guys have any good logs of runs with big temp swings? I've been working on temperature modeling to tune the temperature bias table so airmass calculations are more precise and such logs would be of great help. of course FI cars are by far the most affected by it, which is good for me as the relationships between data will (hopefully) be most visible. if you got anything, please email them to marcinpohl at gmail dot com
Coolant starts at 180 and IATs at about 80.
Coolant ends at 186 and IATs were about 155 (a2w but not a big enough water pump).
Things like that make me wonder how fast we really could have gone if we have kept trucking at it but better things to come soon!
7 Second Club
I have never had any big coolant temp swings, 2-4 degrees even on 90 degree days on a 1/4 mile pass. IATs go up 40-60* from where it starts on a 1/4 mile pass depending on the blower or pulley I use. On a cool day you are looking at 70-110* with the D1 and on a 90 degree day 110-170* with tha F1A.
Which water pump do you run?
