Upping the boost, couple questions.
I'm currently running 8lbs of boost. I'm planning to up it to around 12 or 14.
Do I still want to use TR6's or should I go with a different plug?
I currently have a Walboro 255lph fuel pump, is that enough to support that much boost safely?
Is there a certain weight of oil i would want to use with higher boost?
I would maybe try the TR7's and see how they work...
I would definitely go with another pump and maybe steel braided lines... You could also try a BAP to see if your pressure drops off and if it doesn't and you're not going lean then you're probably safe...
As long as your rings are good I would say stay with the same oil you're running now....Just change it often as usual...
