a few wiring questions for you turbo guys- fans- map- etcc
question 1) do you guys know the polarity of the wires to run aftermarket electric fans as pushers or pullers ?
question 2) is there a wiring schematic for aftermarket 2 bar map sensors or does it replace the factory sensor ?
i figure since probably all the turbo guys had to deal with wiring and what not on their vehicles it'd be a good place to ask.
Originally Posted by smokinHawk
since the fans use a DC motor you just have to hook them up so they blow the right way. if its not you switch the polarity, simple as that (provided the fan is mounted in the correct direction)
