cam and injectors for turbo
Old 07-10-2007, 07:31 AM
whitedevilWS6's Avatar
Default cam and injectors for turbo
i was thinking of running an STS w/ 67mm upgrade. would a 226/228 113lsa cam be too aggressive? i was also thinking of using 61# injectors. i've heard that those injectors are overkill for only about 8-10 psi and will go bad because they're too big and/or they'll dump too much fuel. any help?
Old 07-10-2007, 08:13 AM
SonofaBish's Avatar
i'd say the cam will be a good one... i wish i had gone with one a little more like that..... only has 1* of overlap if i calculated in my head correctly
as far as the injectors.... dunno... i'm using 60's for about 14-15 lbs boost... i think they'd be ok, but i'm no expert so i might be wrong
Old 07-10-2007, 08:23 AM
Ironmancan's Avatar
Had 60lbs on mine when I was running 9 lbs of boost no problems. Still using them for 15 lbs. I know quite a few that have the same injectors and are running the same boost (9lbs) no issues either.
Camp Lejeune eeh. I've got orders there to 2nd Tracks I'll be checking in Sept 1st. Big step down from Tampa but what are you gonna do
Old 07-10-2007, 11:18 AM
Closed Sponsor Account
Josh@MASPORT's Avatar
the 60pound injectors are very good for almost any setup, especially because u wont have to buy new ones down the road (ive used 60pound inj. on a stock motor).
i can set you up with a great deal on MSD 60pound high impedence injectors, let me know..
JOSH
Quick Reply: cam and injectors for turbo
