Turbo cars with aluminum vs. steel flywheel
I've run both. The heavier flywheel will get you out of the hole better but it's harder on parts. On an already heavy twin disc, I choose to go aluminum the second time out. Aluminum will make more power to the wheels and rev faster due to lower mass.
Very interesting. Ive been debating the same thing! My car will be a heavy pig, (close to 4000lbs) so I was thing a steel flywheel but never took in account the heavier twin disk clutch. Im sure your cars are alot light than mine, so it hard to compare. How "boggy" is the launch with a AL flywheel?
Thanks - Ron
Thanks - Ron
I wold rather have a bulletproof strong flywheel, than a light one.
Given the power these motors make, I would think it safe to say, there would be no measurable difference in acceleration perforance between a steel or alloy flywheel in real life.
