need help installing synergy 2-step for an M6
Old 08-08-2007, 10:15 PM
SVC707's Avatar
Default need help installing synergy 2-step for an M6
i got this new off a member on here. and stated its for an m6... its got the wires and directions for an m6, but the clutch switch doesnt seem to match
it says the grey wire goes to C1-35 (blue) clutch switch, that location is empty in my harness. so maybe he had a different year.
the coil wires seem to match up ok though, color of wire in harness to color of wire on coil
Old 08-09-2007, 12:46 AM
SVC707's Avatar
got everything but the clutch switch wired up. all of the other wires matched pretty good from synergy box to ecu wires. same color and stripe setup, made things easy to figure out there.
if anyone just knows which wire to use for the clutch switch?
Quick Reply: need help installing synergy 2-step for an M6
