Thoughts on a PT91 vs. GT47-88?
Old 09-10-2007, 10:14 AM
Fireball's Avatar
Red face Thoughts on a PT91 vs. GT47-88?
Currently I have a GT47-88 turbo on my build. I have come across a killer deal on a new PT91. I know the GT47's turbine is a tad small for a 350+ ci engine (mine is a 366). Are there any "negatives" known about the PT91s?
Old 09-10-2007, 05:01 PM
otherwhitemeat's Avatar
It's a lot bigger in size and you'll need to cut stuff to get it to fit...
Old 09-10-2007, 05:45 PM
red beast's Avatar
I didn't know a gt-47 was small
Old 09-11-2007, 06:30 AM
Fireball's Avatar
shoot...just looked it up, it a thumper sized turbo...yup probably won't fit
Old 09-11-2007, 06:58 AM
Websy21's Avatar
keep the twins bro
Old 09-13-2007, 12:16 PM
bumpin_records's Avatar
well since it wont fit can i buy it
Old 09-13-2007, 12:18 PM
H8Mac's Avatar
Sure it will fit... Just cut her up...
Old 09-14-2007, 12:26 AM
2000 Tran Zam's Avatar
Id sell my GT55 if anyone is interested... I need a gt47-88.
Old 09-14-2007, 06:19 AM
Fireball's Avatar
u have pm
Old 09-14-2007, 06:33 AM
Fireball's Avatar
Can a GT55 turbine wheel be installed on a GT47? I'd prefer to stay 88mm to fit more class rules if possible...
Old 09-14-2007, 10:52 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,103 Likes on 723 Posts
I'd consider trading for that GT55-91, pending some research. Let me know.
Old 09-14-2007, 02:19 PM
pmed both of you back...
Old 09-14-2007, 02:21 PM
Fireball, I think it wont fit cause the housings are completely different in size...
Old 09-14-2007, 03:01 PM
LS1Tech Co-Founder
I think there is some sort of hybrid GT47-88 with a 91 wheel, but you'd have to ask someone like Brian M. over there to be sure. I thought Sound Performance had done something like that once... I'm not sure.
Old 09-14-2007, 06:01 PM
NA$TY-TA's Avatar
1st why are you wanting to go down in size with your set-up???
Your going to start to run into back pressure problems with a smaller turbo...
I thought your Turbo was hurt... ie broke???
Call up Jose at Forced inductions.... he has some new stuff.
I know somebody trying some stuff
Kyle
Old 09-15-2007, 04:06 AM
Kyle
Few reasons...
First, I want to spend as little money possible to fix my setup and get it running right. second, I dont plan on making more then 9xxrwhp so either turbo will get me there. third I think i would spool a bit faster with the smaller turbo, plan on running 10-12psi on 91 with some 101 in there just to be safe, then 16psi or so on 101 for my race setup. Fuel system wont support more then 9xxrwhp so why spend extra money for no reason?
Ya, turbo needs a new wheel and bushing but can be fixed easily...
I understand backpressure issues, but that usually happens with a 76 or maybe 80 wheel on a 408... ive seen plenty of people run pt88s on 408s, 402s, etc...
Old 09-15-2007, 06:58 AM
Fireball's Avatar
shaft is though....probably needs exhaust housing and turbine wheel...
wonder if this is what's considered a GT55-88?
Old 09-15-2007, 11:19 AM
Isnt that the bulk of the turbo though... the housing and the wheel?
I didnt know they had settings to made it fit an 88 wheel, but I know jose and them always have something cool goin on
Old 09-15-2007, 06:19 PM
Fireball's Avatar
can reuse the chra, compressor wheel and compressor housing to my knowledge.
Quick Reply: Thoughts on a PT91 vs. GT47-88?
