procharger d1sc oil problems?
Old 09-12-2007, 07:17 PM
ZDOG's Avatar
Default procharger d1sc oil problems?
well it all started when during a moment of weakness i blew my oil dipstick and spewed all over my engine before i ever had a chance to put it in fourth. im now seeing oil around the fresh air hose at the intake hat. is it possible i experienced enough blow by to send oil to the plastic intake hat and shoot my oil stick? whats the commom setup to help this? im thinking a check valve on the fresh air hose, or running to catch cans. one for the pcv and one for the fresh air hose. i need to pull my hoses to see if i shot any oil on my mass air flow. i was thinking i had bad ringlands but maybey its just some good old blow by. ill run it till it grenades i just want to keep the oil in the motor. any ideas?
Old 09-12-2007, 08:58 PM
EPP
EPP's Avatar
Smile
http://www.exoticperformanceplus.com....html?item=756
We have found this filter to greatly help out. Bob
Old 09-12-2007, 09:25 PM
ZDOG's Avatar
does oil weep from that? also does it shorten the life of the oil?
Old 09-13-2007, 05:13 AM
EPP
EPP's Avatar
Smile
OIl can indeed weep if you have a lot of blow by. We've used these filters on quite a few cars and have not had any long term complaints about oil seeping from them.
Anything that is not 100% sealed can possibly shorted the life of the oil, but normally it is releaving pressure. Bob
Old 09-15-2007, 07:28 PM
ZDOG's Avatar
so if i use this filter to i ditch and plug the fresh air hose going from the valve cover to the ati intake hat?
Quick Reply: procharger d1sc oil problems?
