Which 3 disc Vig are people having the most luck with?
I'm going to "upgrade" and possibly restall from my single disc 3200 Vig. Car turns the single disc 3200 into a 3800-4000. I hear the multi discs are built tighter. This is a track first, street second car. I've searched and the info seems to be all over the place. Thanks in advance for recommendations. 402/13psi.
i think youll have too much stall, youll want to take advantage of the tq curve. a 3200rpm stall should be fine.
there is a formula that you used to figure out what the best stall speed based on your dyno chart.
