Ati Balancer Q"s
Old 11-28-2007, 04:50 PM
allthrotle's Avatar
Default Ati Balancer Q"s
I bought a d1sc 8rib kit. I was told that I have to buy the ati balancer, Im confused as to what part # I need to buy, I called ati and they said I need part # 917345A, I look and EPP website and they list a different part #. Im just confused as to what balancer I need.
Old 11-28-2007, 05:15 PM
BlkHwk's Avatar
http://www.atiperformanceproducts.co...ts/damserp.htm
Old 11-28-2007, 05:20 PM
TT-TECH Veteran
Inspector12's Avatar
Well EPP is probalby listing one with 10% underdrive and they are probably recomending an OEM diameter pulley etc... You just need the 916031 steel hub with which ever shell you want either stock diameter or 10% under drive with or with out A/C, if you are going to be over 700hp go for the stock diameter IMO as it has more dampning ability. Good luck.
Old 11-28-2007, 05:40 PM
allthrotle's Avatar
Ok so your saying I can get any ati balancer for an ls1 and it will work with the 8rib kit.
Old 11-28-2007, 05:56 PM
TT-TECH Veteran
They all have the Three bolts that attach the blower drive pulley so basicly yes LOL! Just make sure it has a STEEL Hub cause the aluminum will not be good for this type of service.
Old 11-28-2007, 05:57 PM
TT-TECH Veteran
Oh by the way did I mention I was selling one with 10% underdrive and two keyways 180* out.
Old 11-28-2007, 07:11 PM
allthrotle's Avatar
OK cool thanks.
Quick Reply: Ati Balancer Q"s
