3 bar map not showing boost
Old 12-14-2007, 10:16 AM
edcmat-l1's Avatar
Default 3 bar map not showing boost
Part number 12223861 works fine to 105 Kpa. Doesnt show any boost at all. Kpa key on engine off is 105. Hooked up right. 3 bar OS is applied and working correctly. RTT is working. Just isnt showing any boost. Thoughts?
Old 12-14-2007, 10:28 AM
qqwqeqwrqwqtq's Avatar
You have to turn the key on, connect scanner. After it's connected, disconnect, go to chart settings and change the standard map pid to 3bar map pid.
Old 12-14-2007, 10:33 AM
firehawk123's Avatar
did you got your scanner set for that.
Old 12-14-2007, 10:54 AM
edcmat-l1's Avatar
Thanks man. I'll check that. Never had to reset for a 2 bar. Is it just the 3 bar you have to do that?
Old 12-14-2007, 11:04 AM
edcmat-l1's Avatar
Mo betta now. thanks
Quick Reply: 3 bar map not showing boost
