Oil line restrictor install question
On my Twin Turbo setup Iam running a sandwich adapter between the oil filter and the block, and that adapter has one (T) fitting connected to it, and each side of the (T) supplies oil to one turbo
Iam planning to install oil restrictors, should I install two restrictors at each side of the (T) fitting? or would a single restrictor at the source of the oil going to the (T) be sufficient and work just as good?
Merry Christmas & Happy holidays to all
Probably would work either way, but I would run two seperate restrictors in case of a flow resrtiction to one turbo. If one had a slight line restriction, the oil may go to the other turbo if it is restricted before the tee.
Kurt
Kurt
