pre-turbo oil filter, any rear mounts run them?
Old 01-18-2008, 08:42 PM
RooRnZ28's Avatar
Default pre-turbo oil filter, any rear mounts run them?
I have seen certain vettes with pre-turbo oil filters that they run on their rear mounts, and i was wondering where they can be purchased?
i would also like to discuss their uses, like would they extend the life of the turbo and return pump, and would it be worth doing? i am looking at all the possible things that could be done to maximize turbo and pump life, and was wondering what ya'll thought as well. thanks!!
Old 01-19-2008, 09:37 AM
John_D.'s Avatar
My oil feed to the turbo is right after the stock oil filter has done it's job. I'm ok with that.
I could see if a separate oil pump was being used to draw oil from the pan, to feed the turbo, there should definitely be a filter before the turbo. That approach would keep a leak from stealing oil pressure from the engine internals, at least until the oil in the pan got pumped out...
Quick Reply: pre-turbo oil filter, any rear mounts run them?
