Build A New Setup And Could Use Some Ideas....
Restricted User
I'm working on building a new motor for a twin turbo setup. I'm going to be running an APS twin turbo kit for an LS1 F-Body, thats the part I'm certain of, my motor is what I'm concerned about.
Within the next few weeks I plan on purchasing an LS1 block and I will begin to start piecing it together. I will be using Wiseco pistons with a -31 volume I have not decided wether to go with the 3.900 bore or the 4.000 bore. With either piston I will need to run a 6.125 rod, which will more than likely be one of the Manley I-Beam rods. I am also thinking about running AFR 225 64cc heads and with those pistons should put my compression around 9.2:1. Thats pretty much all the research I have done or I should say the parts I have decided on yet. I am still trying to figure out what else I will exactly be needing to my specific build. If you have any idea, tips, or just happen to know what part or parts would help out with my build it would be greatly appreciated.
-Dave
-Dave
