New FI Owner
Old 02-12-2008, 08:46 PM
4mula4ever's Avatar
Default New FI Owner
Well guys, Saturday I'll be buying my new Camaro. A z28 with a TTI 76mm street kit. Anything I needa know before I get myself into it with not much knowledge? What I'm really looking for is fuel related. It has 42# injector and I'm thinking I'm proboably going to go with 60# but not sure what people do for fuel pumps.
Thanks
Old 02-13-2008, 09:10 AM
4mula4ever's Avatar
nobody? Saturday is getting closer.
Old 02-13-2008, 10:36 AM
98Z28MASS's Avatar
Have a ready supply of spare underwear!
Old 02-13-2008, 10:40 AM
98transguy's Avatar
60# for sure , fuel pump depends on how much boost u plan to crank it to, dual in tank walbros would probably get u pretty far.
Old 02-13-2008, 10:42 AM
4mula4ever's Avatar
it at 8 lbs now
when i get all the fuel system done i wanna pump it up to 10 or so
Old 02-13-2008, 10:54 AM
2000 Tran Zam's Avatar
dual 255 walbros should support over 7xxrwhp id assume... and with 60#ers they are good for mid 8xx (although in some rare cases ive seen in the 9xx's).
Old 02-13-2008, 11:39 AM
4mula4ever's Avatar
so dual 255's and some 60# injectors shoudl be good to run to full potential
Old 02-13-2008, 11:52 AM
Ya there shouldnt be any issues with that as a setup... seems to be reliable and you wont have the issues of having one massive pump like I did.
I dunno about full potential... is the motor forged? if not you might only be able to squeeze out upper 5xx, low 6xxrwhp before the motor pops...
Old 02-13-2008, 12:04 PM
4mula4ever's Avatar
ya its a Forged 347, with stock 6.0 heads (918 spriings). ARP bolts throughout.
LS6 intake, cam specs (220/224 .585 .585 116)
Old 02-13-2008, 12:09 PM
98transguy's Avatar
should be a nice setup , once u get the fueling figured out, how much power are u looking for
Old 02-13-2008, 12:20 PM
4mula4ever's Avatar
it had the 60-1 kit on it and made 510 rwhp and 560 rwtq so im hoping to bump that up quite a bit with everything and be running the 1/4s fast enough i have a reason to replace the rear
Old 02-13-2008, 12:31 PM
98transguy's Avatar
car still has stock rear? yeah that wont last long, suprised it lasted with the 60-1 on there
Old 02-13-2008, 12:43 PM
4mula4ever's Avatar
hoping it wil last long enough to raise funds to get the fuel system done and get the $ for a 12 bolt
Old 02-13-2008, 12:52 PM
98transguy's Avatar
i would keep the boost as low as u can.probably talking about 3-4 grand or so if u do the work yourself.how about the tranny, what kind does it have now?
Old 02-13-2008, 12:53 PM
4mula4ever's Avatar
its a build 4L60, with a midwest 3800 converter and B&M tranny cooler
Old 02-13-2008, 12:58 PM
98transguy's Avatar
might want to consider starting to asve for a tranny also, most 4l60's built or not dont like 700-800 rwhp . no one has asked but i assume the motor is forged rods and pistons?
Old 02-13-2008, 01:17 PM
4mula4ever's Avatar
yeah its all forged internals
Old 02-13-2008, 01:32 PM
barnat's Avatar
Default Fuel?
Thanks
Nasty performance WILL!!!answer all your fuel needs,Nate is a great guy and WILL!!spend the time with you on the phone to answer ALL!!your questionsBARNAT
Old 02-13-2008, 02:21 PM
4mula4ever's Avatar
barnat, thanks. I appreciate it
Old 02-13-2008, 02:23 PM
4mula4ever's Avatar
98transguy, u say i might wanna start saving for tranny too? It'll last longer then the rear and everything tho correct?
Quick Reply: New FI Owner
