Turbo set up
Turbo set up
I already have some parts for the new setup, but i need to know what kind of turbo kits are the best from those who have used them. I have a 383ci with AFR 225's. Compression ratio will be 9.0:1. Bottom end has a callies dragonslayer crank, compstar rods, and diamond pistons. This will be a street car and the main intention for this setup is to be a supra killer. The AFR heads have already been sent off for additional CNC work. I have a Fast 90/90 that has been port matched to the heads. My question to ya'll is what would be a good streetable cam for this setup matched to what turbo. Im thinking going no less than an 82mm turbo and I am willing to go higher. Suggestions on cam specs?
WOW going big i see
i have a APS set up is this a street car, DD, or drag
you might want to look at EPPs turbo cam its nice and big or LINGs GT-11 is about the same or call COMP and see what they say good luck
street car with over 1000rwhp huh? i would switch your fast 90 intake(there have been some problems with the boost u will be requiring to make 1000rwhp).u are going to probably need something in the 88-91 mm range for the power u want
I figured i would have to go with a carb-style intake manifold. Im probably going to go on and get an 88mm turbo. Still trying to decide on cam specs for the setup.
