Stock Cube Turbo Cam
APS TT, 13+ psi, stock heads, mahle pistons/manley rods, pump gas. This car is a daily driver. 3076r turbos, C6.
Lingenfelter recommended the GT11 cam for my application. What do you guys think?
LS1-GT11 215 / 231 .631" / .644" 1.7 ratio 118
Jim C.
Well I think lingenfelter knows a thing or two. I was going to go up to that cam in my 408 build but worried the high lift will mean doing valve springs every 20,000 or 30,000 or so miles. And that is not fun in a fourth gen,its easier in a vette of course. Also worried that high a lift might cause problems even if a guy uses .650 lift springs as boost can cause more float up top. So for now going to try the mellower ling gt7 cam. Have one around anyway.MIght go with 1.8 rockers to get a bit more lift.
What we need to see is someone with a dyno test three or more cams. Test a reverse split,no split and normal split and test a few different lifts like 550, 580 and 600 and a few lsa....112,114.118..
Personally I believe you can make good power with several different cams since you are forcing the air thru anyway and some say which cam would work best depends on your setup and backpressure..etc. Its all very confusing. APS is doing really good I think with that GT11 in their dynoed 346 built motor. They are running the gt11, fast 90/90 combo and afr 225 heads.
I am hoping to make goal of 850rwhp with 408,gt7,afr 225 and fast 90/90 and underdrive. If don't get there may yank out and try a different cam. The gt7 was used I think in most all the recent lingenfelter twin turbo cars but maybe now they are using the gt11. Before the gt7 the gt2-3 was used a lot.
The gt7 and gt2-3 are very very close to z06 cam specs. I think ling should offer a milder lift gt11....maybe 580 or 590 or 600 max. Not really sure where the lift starts to get high enough to really take its toll on valve springs. I would think past 600.
