well parts are ordered
well i finally got to ordering some parts
8.8:1 compression
New ls2 402 alum block fully cnc machined
main capps pinned to prevent walking
lunati pro series 4.00" stroke crank
lunati billet 6.125 connecting rods
je custom forged pistons-coated on tops and skirts
total seal stainless steel rings
clevite coated bearings
afr 225 cnc ported heads
arp main and head studs
custom comp hyd roller cam
harland sharp roller rockers
ls7 lifters
ported ls6 oil pump
jp performance timing set
comp cams pushrods
balanced rotating assy
fully assembled longblock
ls2 frt timing cover and sensor
ls2 valley cover
ls2 rear cover
carbon fiber hood
slotted rotors
8.8:1 compression
ls7 lifters
ported ls6 oil pump
comp cams pushrods
ls2 valley cover
ls2 rear cover
carbon fiber hood
slotted rotors
well im slapping on a 88mm with custom fuel system,suspension,transmission,rearend,and driveshaft. the guys told me at 16-18 lbs it should be easily 900rwhp and im goin to have it with 20lbs with a 75 shot and should be about 1300rwhp. this car is caged and will be able to run in 9's possibly 8's. keep in mind complete street car and running on pump gas!!! lol
