gasket for TB and elbow??
Old 03-17-2008, 11:41 PM
Rickys S/C Z28's Avatar
Default gasket for TB and elbow??
what are you guys using that have a elbow?? i had not thouht of this till it was asked of me?? any help would be great!!! thanks
Ricky
Old 03-18-2008, 06:56 AM
come on guys i need some help please
Old 03-18-2008, 07:43 AM
jasond26's Avatar
I just went to the local auto parts store and bought some sheets of gasket material, traced out the throttle body and cut out a gasket. Works great so far.
Old 03-18-2008, 08:20 AM
Fireball's Avatar
I did the same thing, except I used a rubber sheet
Old 03-18-2008, 01:16 PM
stevieturbo's Avatar
Im using a Ford TB, it came with a gasket. I did use sealer though, as the flange on the elbow wasnt 100% flat. It wasnt bad, but not good enough.
For the elbow to intake, I had the elbow machined flat, and bolted it up with some sealer, no gasket.
Pressure tested it on the engine, and it does not leak.
Old 03-18-2008, 01:56 PM
TINKRD's Avatar
can't you just use some bookie?
Old 03-18-2008, 07:32 PM
ok guys thats what i thought i should do thanks for the input
