12 psi fueling needs with meth.
Old 03-22-2008, 06:07 PM
02NBMFormula's Avatar
Default 12 psi fueling needs with meth.
I am going to bump the boost up to about 12 psi and wanted to see what everyone is running fuel wise. Im guessing that it will be around 600rhwp??? and so i plan on adding a hot wire kit and meth to take care of the fueling needs (60lbs and walbro currently) will this support it? is this a dumb idea? twin intakes better???
Old 03-23-2008, 09:12 PM
ttt....
Old 03-24-2008, 08:09 AM
Dumb Ass Vette Moderator
ls1290's Avatar
The BAP approach is always a band-aid solution. The best solution is always getting the right sized pump for your needs. I think the 255L will be right on the edge for 600 rwhp @ 12psi. Personally I would ditch/sell the 255L and BAP and get a 420L pump. That should handle 600 rwhp no problem.
Keith
Old 03-24-2008, 04:27 PM
is that a intake pump?? drop in for the 99+ bucket? link?
Old 03-24-2008, 06:56 PM
big reg's Avatar
Also interested. I know the Bosch 420l pump is an inline pump. Will it bolt right up?
Old 03-24-2008, 09:49 PM
GMmotorgirl's Avatar
do the twin intank you can build a twin set up for 30 bucks plus pumps and its real easy
Quick Reply: 12 psi fueling needs with meth.
