Instant fittings
Old 03-30-2008, 09:48 PM
7 Second Club
Phil99vette's Avatar
Default Instant fittings
For you guys using instant fittings is 1/4" OD big enough for WGs and BOVs? Tial seems to think that 1/8" ID is not big enough for a BOV.
Phil
Old 03-31-2008, 07:19 AM
DuronClocker's Avatar
Haven't run it yet, but that's the same size my "big red" ATI race bypass valve came with.
Old 03-31-2008, 06:02 PM
stevieturbo's Avatar
I initially tried 4mm OD on my car. I then switched to 6mm OD tubing.
The small diam tubing should be fine, but if the diaphragm/chamber of the BOV has a slight leak, then that small loss of air, can be a big thing with such small diameter tubing, and signal strength can be lost.
I'll continue to use 6mm OD
Old 03-31-2008, 08:03 PM
Jake@EPP's Avatar
Phil
Quite a bit of people run the 1/4 legris fittings without issue.
If this is of big concern, the more expensive but more flexible option would be -4an fittings.
Old 03-31-2008, 09:35 PM
BigBronco's Avatar
Sorry I did not get back to your PM Phil.
I would say a 1/4" minimal ID. I know of a couple cars running with that and not having an issue. I know that is What Jake @ Tial suggests as well.
Quick Reply: Instant fittings
