Anyone using the lq4 373 iron heads?
I bought these thinking they were the 317 heads. Anyone using them? Are they any good for a high boost application? I think they are going to bring my compression way lower than I wanted, 8:1 or maybe even lower with my -28 dish pistons. I'm only using them as a temp until I have the money for a set of the 6 bolt etp heads but I would like the car to still put down some good power for now. I should be seeing around 25-30psi
Here's the specs I found with a search.
Casting Number 373
Head: 1999-2000 LQ4 6.0 Litre Truck
Material: Cast Iron
Part Number:
12561873
Combustion Chamber Volume: 71.06cc
Compression Ratio: 9.5:1
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
The only positive I can see over the normal 317 is that they are iron, possibly a better chance of not lifting the heads?
How do you guys think they will work?
Forgot to mention they will be on a 402 LSX with a F2.
Casting Number 373
Material: Cast Iron
Part Number:
12561873
They'll work, I just think tha twith a forged lower compression motor I would have just run the stock heads till I could get the betters ones. I got the 317's just to be alittle safer on the stock internals til I get a forged motor.
Heres stock specs to compare:
Casting Number 241
Head: 1997+ LS1 5.7 Litre Passenger Car
Material: Aluminimum
Part Number:
12559806 (1997-98) Chambers = 69cc
12559853 (1999-00)
12564241 (2001-03)
Combustion Chamber Volume: 66.67cc
Compression Ratio: 10.1:1
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
